My budget tech 1 turbo
Gunni
Post Tue Sep 11, 2012 9:29 pm
no, spark advance needs to be contained.
Gunni
@ 2012 VEMS group buy !!
b12rlw
Post Tue Sep 11, 2012 9:41 pm
Yeah, the car still has to be mapped , I had an eager right foot when pushed by some guy on a gsxr 750 and this was the result. Was thinking it's worth having the head strengthened to take higher boost for when I go forged down below. Gunni have you done any builds where the head has been done? What sort of boost am I likely to run on stock pistons/crank/rods???
maxfield
Post Tue Sep 11, 2012 9:45 pm
You using arp head bolts?
b12rlw
Post Tue Sep 11, 2012 9:48 pm
Yeah mate.
fowler
Boost Junkie
Post Wed Sep 12, 2012 10:37 am
with gunni on this one !!!!!! requires mapping before driving in anger i have done many times mine is knobbled to about 60% capability till i can get to see Mr :D Gunni work permitting
EX A-Tech Workshop bitch !!!
gone but not forgotten
b12rlw
Post Wed Sep 12, 2012 6:12 pm
It's gonna get mapped soon as it's back together. I'll get the head done then fit the new fuel pressure regulator and have it trailered to the rollers.
Gunni
Post Thu Sep 13, 2012 10:29 pm
b12rlw wrote:Yeah, the car still has to be mapped , I had an eager right foot when pushed by some guy on a gsxr 750 and this was the result. Was thinking it's worth having the head strengthened to take higher boost for when I go forged down below. Gunni have you done any builds where the head has been done? What sort of boost am I likely to run on stock pistons/crank/rods???
What do you mean by head been done?
Many of my friends have had heads welded. Just as many have not and not had problems.
A standard head with standard cam will do you 500+ all day.
Depending on the turbo you use I´d reccond rods bend at 500lbs roughly, given petrol you´ll melt the pistons at roughly 500hp.
Crank will NOT fail under power or boost.
Gunni
b12rlw
Post Fri Sep 14, 2012 9:25 am
Nice figures ;-). I'm just thinking, it's worth doing the now as that's where it popped, the head is off and it's another means of future proofing.(one less niggle at the back of my mind).
b12rlw
Post Sun Sep 30, 2012 6:05 pm
Welded head. Before and after pics. The man with the van I'll be round either Mon or Tue to skim.
b12rlw
Post Sun Oct 07, 2012 7:39 pm
Skimmed and ready to be rebuilt. Should get it back together tomorrow. Then it's a case of boxing back up and an oil change.
mongomushroom
Post Tue Aug 20, 2013 12:15 am
Hi,been following your build. Any updates?
b12rlw
Post Sat Aug 24, 2013 6:34 pm
Yeah, got pics for updating at some point. Sorry for the long drawn out thread but I've spent the summer preparing for my final exams at uni..... soon I'll have a BEng (Hons) in Mechanical Electronic Systems Engineering. Can't wait to have it done and dusted, it's been a long slog.
Anyway, as it stands, the car is in my lockup waiting for the rebuilt diff to be refitted, just need lsd oil. It's had new bearings, seals blah blah but the most important thing is the reduction in gear ratio from standard to 3.15 in an attempt to better utilise the turbo torque.
I've also fitted the weber cossie fuel pressure regulator to the rail by b@5t4rdising a remote adaptor and turning a new "spool" piece. Pics to follow.
The rear beam is to be rebuilt with poly's, new cables/ flexis and hard brake pipes. I'm gonna be replacing my racing dynamics arbs with h&r items along with billie and eibach suspension. Watch this space.......
mongomushroom
Post Tue Aug 27, 2013 2:42 am
cheers for the update. look forward to seeing the photos.
good luck with the exams
b12rlw
Post Fri Aug 30, 2013 7:25 pm
Some pics to detail some of the steps taken to rebuild my diff. Not all info is here cos I forgot to snap pics of setting the diff up.
Painted case and new bearings supplied for 25% less through thebearingcompany rather than our procurement company at work. Longer 3.09:1 gearset pinion in shot.
Spacer ring behind pinion Inboard brg.
Pinion inboard brg outer race after being driven home.
Inner race on the heater. Set at 150deg, usually enough for any brg. Pinion in shot
Some stiction resulting in the use of....
Resulting in........(note clamp bush)
Pinion outboard brg outer driven into housing
Mounted to take housing
Like this..
Ain't got pics of the outer being nipped up but rotating torque (drag) set to 24nm if I recall correctly, got it dotted down somewhere.
Updated (deeper socket) capscrews torqued and studlocked, 3.09:1 ring gear fitted with torque and studlocked bolts.new brg fitted after a gentle heat (110deg)
Carrier in. No pics of outers in the covers. Should mention, new friction plates and dog-ear rings too.
Boxed up, backlash set to 0.07mm (by hand before measurement - not a bag guess). Also wear pattern near perfectly centered, again carried away and no pics, plus managed to get marking blue everywhere too.
Powerflex black bush and Mobil ls diff oil fitted.
More to come.........
b12rlw
Post Fri Aug 30, 2013 7:42 pm
Oh, some scrap
And the fpr fitted to the rail, $hite pic, better to follow.
Potential new bus for the wife.... still undecided, 900cc and no remaps available yet???
b12rlw
Post Thu Sep 12, 2013 6:21 pm
Little update, not the most exciting but progress all the same. Diff Is back in, after some jiggling and new fuel lines fitted. Took the car for a blat behind the lockup and am very impressed with the improvement in gearing. Should be fun once the car makes it to Manchester for mapping. Currently looking for 1.5t beavertail for hire. Soon...........
b12rlw
Post Mon Nov 11, 2013 3:24 pm
Plans have changed again slightly. I've decided to completely rebuild the back axle and deal with any rust/rot along the way over the winter.
First installment of some new parts,
New rubberz for the trailing arms and beam mounts. Wilwood twin-pots to follow.
Bought these panels for £50. Any experience of hadrian panels pattern fitment?
Need a rub down due to some surface rust spots but in decent nick.
Lurch320i
Post Mon Nov 11, 2013 7:54 pm
Let us know if those hadrian panels fit well.i was looking at their slam panels and floor pans
b12rlw
Post Mon Nov 11, 2013 8:23 pm
floor pans? you got a link?
mongomushroom
Post Mon Nov 11, 2013 8:59 pm
Got the same wing, fitted ok
