supercharged m50 e30 project
makman
Sat Jun 22, 2013 11:51 pm
Just thort id start a thread for my project! Ive not done much so far but ive already done the m50 conversion and its runing sweet. Ive bough a gen1 Eaton m90 twinscrew charger from a jaguar xkr and ive just rebuilt it.
Plans are bigger injectors
Relocate the tb
Standalone managent or a chip? Dependant on boost levels etc
Custom bracket
Run it from th a/c puley
Intercooler etc
So watch this space! Eny advice is highly appreciated also..not many people blower them so i thort bugger it..everyone loves a whine, apart from when its from a complaining woman! :)
Canny Beat a chromie!'
Gunni
Sun Jun 23, 2013 10:50 am
Do you have a compressor map for that supercharger so you can succesfully run the charger at the right speeds and choose how much power you are after?
From there injectors sizes and possibly tuning choices can be suggested.
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
makman
Tue Jul 02, 2013 6:35 pm
How do you mean mate? Im going to run it off the ac belt pulley and use the stock pulley for the time been and plumb a boost guage in to see what its doing. All help/advice is appreciated
Gunni
Tue Jul 02, 2013 6:58 pm
To properly run a supercharger you need to know at what charger speed you need to run it for the engine. I.e the pulley ratio between the charger and the engine. To do this properly it´s best to know the airflow/pressure character of the supercharger and then math out the ideal speed so you can then figure out what pulley size you need on the engine or charger to get that speed.
Gunni
moggie
Tue Jul 02, 2013 8:56 pm
would love to see this makman,i need to come over in my e30 its on the road now and i only live at sharlston .are you going to the nostel fueled society show?
makman
Tue Jul 02, 2013 10:18 pm
Gunni thanks for the advice..is they a chart i can input data into to work this out. And yeah moogie my mate jim novaks organised it all..il be on the inspired automotive clubstand. Will ave to meet up and ave a beer.on the day...lucky to have a weekend pass so i can ave some beers aha
moggie
Wed Jul 03, 2013 7:27 am
nice one im picking my weekend pass up before the end of the week,my mate at work also knows one of the organisers his names ashley he has done a few vw split screens,t4s,t5s ,see you there!
moggie
Wed Jul 03, 2013 10:04 am
http://www.rbracing-rsr.com/turbotech.html
scroll down this page makman,your chart is on there :)
makman
Wed Jul 03, 2013 10:02 pm
Sweet moogie..to all things above aha
makman
Mon Sep 16, 2013 10:43 pm
Eaton m90..custom brackets..custom belt & tensioner..custom intake & re routed afm and icv. Needs some 440cc injectors and a miller war chip. Adjustable fuel reg. Yeah..she runs now aha need a custom boost pipe making and a fitting for the forge 007p valve. Running no cooler as of yet due to around 9psi. Im also aware my boost guage says turbo....
Lurch320i
Mon Sep 16, 2013 11:45 pm
Looks good mate.try aus or usa ebay for the injectors.just got my 42lb injectors delivered today
makman
Tue Sep 17, 2013 11:37 am
How much for matey? Does eny
one know what m50 injectors max out too?
makman
Tue Sep 17, 2013 11:39 am
Little cheeky un lol
Lurch320i
Tue Sep 17, 2013 12:24 pm
I won them on an auction for $26aus which is about £15 and postage was another $25aus
all in all about 30quid to my door
genuine Bosch ones too
they are used but will be sent off for a clean and need o rings etc.
moggie
Tue Sep 17, 2013 5:36 pm
looking good mate
ashton
Thu Sep 19, 2013 5:23 pm
hi mate looking good :) i am in the process of twincharging my 325 turbo using a eaton m62 'charger..got it initially mounted up, and am using a m50 serpentine crank pulley instead of m20 a/c pulley to get everything running before getting custom pulleys made for more boost-how did you line up the s/c with the crank pulley? is a straight edge across both enough to get the belt running true? cheers, cant wait to see yours when it is done :) ash
makman
Fri Sep 20, 2013 9:23 pm
Yeah ashton a straight edge is what i used..got it sat against the waterpump pulley and pas pulley then when by eye..made my brackets adjustable too so i fine tuned it from there. Also made a custom alternator bracket and tensioner system for the alternator to run from as thats where the AC pump used to be. The alternators gona be running from the Ac pulley from the crank too. Nearly done now tbh..just need to weld a fitting for a recirc valve onto my charge pipe then fit an adjustable regulator for the time been. Can you post vids on here from mobile? If youve got fb pm me your name and il tag you in the vid if not. Sounds iimmense haha
makman
Mon Sep 30, 2013 1:29 pm
Need some 440 bosch green top injectors if enyone has a set of 6 for grabs?
rix313
Fri Jan 31, 2014 11:03 pm
Speak to James at injector tune he will be able to supply you with what you need.
makman
Mon Feb 10, 2014 9:19 pm
nearly done! :)
trying to retrofit an s50 m3 coil pack cover on lol
got my new radiator for it, need to make some new brake pipes up and plumb in the hydraulic handbrake and some other little bits then shes good to go!
running bosch 440cc green giant injectors and a miller war/402 ecu with a base charger map/330cc injectors, so il fine tune it with my wideband and hopefuly make some good power!
makman
Mon Feb 10, 2014 9:20 pm
tune is for 330cc injectors sorry.
moggie
Sun Feb 16, 2014 8:54 am
looking very nice that mate,you taking it to fuelled society again
SteSE
Heading for the Naughty Room
Mon Feb 17, 2014 10:47 pm
Sweet ride man! Turbo Tim bought back some memories too. Let's see that vid
87.5 Impact FM
PS3: gary_bunter
1986 325i resto - M52'd
C plates are fastest
ashton
Sun Apr 06, 2014 10:20 am
Any updates on this? My twincharge project is crawling forward and i need some inspiration! :D
djsimmy
Thu May 15, 2014 8:49 am
dont think Mackie is updating this much but there has been issues with the ecu and map i think
