Rear Beam
fastdave
Post Sat Nov 28, 2015 10:19 pm
Can,t seem to find the torque setting for the 22mm nut on the rear beam anyone please
fastdave
Post Sun Nov 29, 2015 1:47 am
sorry a e30 325 and its the nut that holds the rear beam to the body
maxfield
Post Sun Nov 29, 2015 7:05 am
There's unlikely to be a torque setting as its a bush, tight with a 1/2" ratchet will be fine.
Post Sun Nov 29, 2015 11:50 am
A 1/2" ratchet is for speed tightening a fastener to a point close to its final torque or for removing it after its been 'cracked off'. Anyone else working under my supervision that I catch using a ratchet for anything else is likely to get the appropriate tool that they should be using across the back of their knuckles!
In the absence of a torque setting and torque wrench, close to the correct torque for most fasteners will be achieved by using a conventional combination spanner and pulling on the end of it with a comfortable force with your fingers. (NOT as hard as you can pull.)
fastdave
Post Mon Nov 30, 2015 4:42 pm
Thanks guys I knew I could count on you :D
