is the e34 oil pump the same pump which is on the m50 engines,m52 engines
help much appreciated
e34 oil pump
moggie
must be a guru on here who knows?
Don't understand the question! 520 and 525 E34s (except early ones) use M50 engines, so of course an E34 oil pump fits the M50 engine.
moggie
sorry what i meant was does the e36 m50 engine have the same oil pump as the e34 m50,is it just the pick up pipe which is interchangeable
Yes, pump is essentially the same; just the pick up pipe needs to be changed over.
moggie
thanks brian
