Need some help, mate has a 1998 e36 318Ti which runs perfect until its hot and which point it splutters/is down on power and backfires. Also seems to smell like its running rich. Tested the blue temp sensor both at the ecu then at the sensor itself just to be doubly sure. Was exactly what it should have been.
So any advice where to be looking next/what to test?
318Ti hot running issues
ross_jsy
adamt93
Just take off you air flow sencer and take it for a spin it happened to mine it worked after that so got a new sencer
adamt93
If that's not it tho I don't know :/
