I have bought two directional tyres part worn , 225/50/16 and would like to know if as long as the arrows are pointing in the correct direction, does it matter if they go on the right or left of the car.
The tread is an even pattern acroos the tyre and there are no markings saying "outside" etc.
Many thanks, Mart
Directional Tyres
kam-325i
aslong as the "rotation" arrow is in the correct direction, you are fine.
Assemetric tyres have "Outside" marked on them.
Thanks for that mate.
Mart
Mart
Dezzy
- CR24v it's a lifestyle
If the arrow is pointing forward when fitted to the car, the tyre is fitted correctly.martauto wrote:I have bought two directional tyres part worn , 225/50/16 and would like to know if as long as the arrows are pointing in the correct direction, does it matter if they go on the right or left of the car.
Many thanks, Mart
Anti clockwise pointing arrow is nearside and viceversa
what if you want to go fast in reverse?
- E30 Zone Meets/Events Team
Cooooonte30topless wrote:what if you want to go fast in reverse?
e301988325i
What if the arrow is at the bottom of the wheel?Dezzy wrote:If the arrow is pointing forward when fitted to the car, the tyre is fitted correctly.martauto wrote:I have bought two directional tyres part worn , 225/50/16 and would like to know if as long as the arrows are pointing in the correct direction, does it matter if they go on the right or left of the car.
Many thanks, Mart
I said:
e30topless said:
lock the wife in there
Dezzy
If the tyre is fitted correctly the arrow will always point anti clockwise on the nearside and clockwise on the offsidee301988325i wrote:What if the arrow is at the bottom of the wheel?Dezzy wrote:If the arrow is pointing forward when fitted to the car, the tyre is fitted correctly.martauto wrote:I have bought two directional tyres part worn , 225/50/16 and would like to know if as long as the arrows are pointing in the correct direction, does it matter if they go on the right or left of the car.
Many thanks, Mart
if the arrows point forward on the nearside, and backwards on the offside will it go around roundabouts better?
Got them on a few weeks ago and yes you are right Steve !!!e30topless wrote:if the arrows point forward on the nearside, and backwards on the offside will it go around roundabouts better?
