Hi,
Does anyone have a spare headlamp wiper arm, please?
I only need one (top one wiith the hinged nut cover). - I will obviously take a set.
In actual fact, I don't even need the full arm, just the plastic end piece that holds the ball part of the wiper blade(not sure if it can be separated). Mine is a bit loose, so the wiper blade is not as secure as it should be and falls off.
Please see the image to get the idea of what I am after.
Many thanks.
Headlamp Wiper Arm
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
flybynite
This was posted on the faceache page a while ago. I have not tried any of it yet but I was going to get a set because it's not IF but WHEN the original stuff will break even if you get good bits now.Gert_8 wrote: ↑Thu Sep 07, 2023 12:59 pmHi,
https://www.myclassicparts.com/product- ... ht-wipers/
Someone made wiper blades a while ago and I kicked myself when they stopped and I only got 1 set to try.
Gert_8
HI flybynite,
Thanks for that. The bit that I want is available at $25. USA company?
I'll check and order, but thanks again!
Gert_8
Yes, Dubai. Order despatched by Fedex.
Thanks again. It's a very small part, but it irritates me that the wipers are not complete.
