325i cab exhaust downpipes
guss300
Hi as per title need the exhaust downpipes for a 325i cab
BenHar
The "downpipes" on a cabriolet are no different from any other 325i.
The year of the car is what governs the spec for them.
Ben
Ben
guss300
Many thanks for the info Ben. The car is a J reg. Has anyone got any??
BenHar
If you use https://www.realoem.com/bmw/select.do and put the vin number in you should be able to find the part number you need.
Ben
Ben
guss300
OK thanks will look it up and put it on here
