Clutch master cylinder
Phid
Post Sun Feb 06, 2022 5:34 pm
I need a new one but based on experience with other cars some of the modern stuff is useless. Any recommendations for brands to go for or does anyone do reconditioned OEM?
Post Sun Feb 06, 2022 6:09 pm
F A G clutch master cylinders are decent.
Phid
Post Sun Feb 06, 2022 6:25 pm
I’ve googled it but can’t find a supplier for FAG - any idea where to get them?
flybynite
Post Mon Feb 07, 2022 9:08 am
Phid wrote: ↑
Looking at what is on Autodoc at the moment I can't see FAG listed either. Out of what is there ATE or LuK would be the best but I think you would be ok with Sachs, Brembo, and possibly Valeo, Febi or Metzger for more sensible money as they are all long-standing OEM manufacturers.
If you are looking on Autodoc, beginning of the week on the phone app is highest discount, arrives in about a week from Germany.
Phid
Post Mon Feb 07, 2022 11:14 am
Thank you that is really helpful.
Just trying some reverse bleeding before giving up on the old one!
damers2000
Post Mon Feb 07, 2022 6:59 pm
I noticed a bit of oil on the garage floor, had a look under the car and the side of the gearbox was wet so checked the reservoir which was empty so the slave must have been leaking for a while.
I had a look online and found a shop down south selling the clutch & master for £47.50 by febi so got them ordered and fitted a couple of weaks back. Pleased I ordered both in the end as the master had gone aswell but didn't realise until I took the knee panel off as the foam on the trim was catching the oil.
The febi parts fitted no problem but not surprised really, never had any issues using febi.
onthames
Post Tue Feb 08, 2022 12:30 am
Phid wrote: ↑
I saw the quote Cotswold gave you. £240? Madness. Fag/ate/Luk/Sachs all good suggestions. This list may help you and others out in future:
Boge: Shocks, bushings, top mount.
Sachs: Shocks, clutch, fan clutch, bushings, top mount.
Febi Bilstein: Shocks.
Lemforder: Control arms, bushings, drop links, tie rods, top mount.
Bremi: Distributor cap & rotor.
Karlyn STI: Ignition leads.
Bosch: Lots of electrical stuff, from spark plugs to headlights, ECU, ignition coil, switches, sensors, relais etc.
Hella: Headlights, switches, sensors, relais, taillighthousings, headlight carriers, other electrical- plastic and metal parts.
Jurid-Textar-Ate: Braking parts like discs, pads, booster, master & slave cil.
Lucas Girling-Ate: Brake calipers/rear cylinders.
TRW: Repair kit calipers
Eberspaecher-Boysson: Exhaust.
SKF: Wheelbearings & other bearings.
ZF: Gearbox, steeringrack & pump.
Vickers: Steeringpump.
Behr: Radiator & thermostat. Fan clutch.
Goetze: Headgasket set, other gaskets, pistonrings.
Mahle: Pistons.
Contitech: Auxilairy belts, timing belt.
Mann-Mahle: Filters.
Wahler: Thermostat.
Getrag: Gearbox.
Motometer: Instrument cluster & gauges.
VDO: Instrument cluster & gauges, engine sensors.
Hirschman: Antenna.
Blaupunkt: Radiounits
Nokia Speakers
Brose Electric motors power windows
Ebasto Electric motor roof
Metzeler: Aerodynamic accessories (M-tech) like spoilers, skirts etc.
Pfeba: Aerodynamic accessories
Gerhardi:Facelift Edition side skirts
Stabilus:Shock bonnet
Ribe: Headbolts
Ullringer: Alarmsystems
Phid
Post Tue Feb 08, 2022 6:49 am
Wow - thank you!
I’ve had poor aftermarket parts in the past for other vehicles so like to use OEM for stuff like this.
However I’m not buying OEM at 5x the cost of Sachs, Brembo, etc.
