Have a list of part numbers needed for 325i restoration
Mitchellmoxo
Post Sun Jul 18, 2021 9:04 pm
hello, im not sure if this is the right place. But if anyone has any recommendations of where I can get parts from would be much appreciated.
Gear Shift Selector Parts
Plastic Washer 25111220439
Gearshift rod joint 25117501309
O Ring 25111221243
Shim 25111220199
Circlip 07119932863
Dowel Pin 23411466134
Tension Bush 25111203682
Plastic Washer 25111434194
Sunroof Parts
Cover 54121906710
Circul sliding gasket 54121903725
Front sliding gasket 54128106928
Rear sliding gasket 54121906999
Exhaust Parts
Rear muffler 18101719244
Rubber ring 18211712838
Front Windscreen
Weatherstrip 51311972248
Decorative strip 51311968445
Cup shwarz 51311906604
Rear Widnscreen
Weatherstrip 51311972249
Moulding upper 51311968447
Moulding lower 51311968448
Cup 51311940279
Badges
Front badge 51148132375
Grommet 51141807495
Trunk lid badge 51141872969
Grommet 51141902279
Window Seals
Window sealing 51361904827
Sealing strip 51361924994
Door Seals
Door weatherstrip outer left 51211913055
Door weatherstrip other right 51211913056
Trunk lid gasket 51711884149
Door seal left & right
Bonnet Insulation
Sound insulation set 51481972245
cover 51471933576
Door Break
Door brake 41511884163
Hex bolt washer 07119904459
Pin 51211906799
Lock ring 51211854873
Thank you!
onthames
Post Sun Jul 18, 2021 9:45 pm
Post this in the cotswold BMW section of the forum
Mitchellmoxo
Post Sun Jul 18, 2021 10:44 pm
onthames wrote: ↑
Thank you
