Fog light plugs with some length of wire
BMWM
Post Fri Mar 12, 2021 12:05 pm
Hi
i need a pair of fog light plugs for a e30 1989 model that connect to the fog lights with some length of wire
Bonymaenjack
Post Fri Mar 12, 2021 3:02 pm
BMWM wrote: ↑
Hi
Considering the age and position, myself I'd replace with new, not expensive . I bought new connectors and plugs for my windscreen washer bottles form Cotswold , you receive a far amount of wire "tail " and the plugs securing clips are unlikely to snap .
https://www.realoem.com/bmw/enUS/partgr ... 320i&mg=61
BMWM
Post Fri Mar 12, 2021 9:57 pm
Thanks for the reply
Do you know the part numbers of them at all?
As the car didn't come with any on them they have been cut off by someone at some point
Bonymaenjack
Post Sat Mar 13, 2021 9:46 am
BMWM wrote: ↑
If I remember correctly the connectors into the light are fitted at right angles part number 61131378418
Plug housing,
https://www.ebay.co.uk/itm/BMW-Wiring-C ... 2039446786 but don't buy from the ebay seller use Cotswold so much cheaper
https://www.r3vlimited.com/board/forum/ ... -connector
https://www.eeuroparts.com/Parts/141342 ... 131378418/
