Block connector
Bonymaenjack
Post Sat Jan 16, 2021 7:48 pm
I'm after the 6 pin connector which fits to the AHO motor for the headlight washer system. I'm re installing the system but the electrical connecting block has been cut off . The wiring harness complete is NLA and the OEM does not identify the block as separate entity , so if anyone could help it would be appreciated
sweep
Post Mon Jan 18, 2021 7:30 pm
I may have this part bmw 1371307 part number?
Bonymaenjack
Post Mon Jan 18, 2021 9:07 pm
sweep wrote: ↑
Sorry I don't know , the loom part number is 61121380675 Cable set, headlight cleaning system
https://www.realoem.com/bmw/enUS/showpa ... Id=61_0048
your part number 1371307 looks like it could be it with the same amount of pins and the chamfered edge but the loom colours are not quite the same
https://rrr.lt/en/used-part/ust15138-13 ... iring-loom
Worth a try if its not expensive ? and thanks for responding
sweep
Post Wed Jan 20, 2021 7:07 am
Drop me a pm with your mobile number
