subframe bracket bolt
SHAKEELE30
- Boost Junkie
i need one hex bolt that goes in the rear bracket that holds the subframe up, if anyone has one.
sweep
The splined bolt? What goes up through the floor?
SHAKEELE30
- Boost Junkie
No, it’s the subframe bracket. One on each side, has the big bolt goes through it and then 2 bolts go in from the side, through the body.
sweep
Is it a saloon or cabriolet
SHAKEELE30
- Boost Junkie
Saloon. Are the bolts not the same on all e30s. It’s the small m8x22, Allen key head, 2 on each side ones
SHAKEELE30
- Boost Junkie
No: 6
If you have hex headed bolts on your car, then you already have the wrong bolts fitted, not that it matters much.
M8 x 20 ish cap bolts are readily available from many sources. I'd include a washer under the head when fitting them.
SHAKEELE30
- Boost Junkie
That’s what I was confused about, on realoem it says inner hex bolt, when I’ve searched for that, it comes up with different types of bolts from what I’ve got already.
