hi all
Need a purple tag steering rack to do swap with on my 1991 e30 cabby...all advice welcome, is this the best one to fit...
Ozzy
ozzy2006
Has no one got one of these... And all the bits for the conversion
Dlb26
Yes purple tag highly regarded as the one to go for. There's plenty on ebay and DanThe on here is the man for hoses and coupling although you can make a hybrid coupling as per the wiki if you are handy with a bit of metal work. Dan's hoses are very good quality, didn't use the coupling but I have no doubt it is equally high quality. Read the wiki section regarding inner and outer ends you'll need.
ozzy2006
Thanks for the info... Will give DanThe a shout... And look up the wikiDlb26 wrote: ↑Thu Aug 06, 2020 10:07 pmYes purple tag highly regarded as the one to go for. There's plenty on ebay and DanThe on here is the man for hoses and coupling although you can make a hybrid coupling as per the wiki if you are handy with a bit of metal work. Dan's hoses are very good quality, didn't use the coupling but I have no doubt it is equally high quality. Read the wiki section regarding inner and outer ends you'll need.
