one for the engineers??
steve_k
evening folks,
looking for a bit of advise in regards to my daily (audi a4 b6 1.9tdi)
i'm in the middle of replacing the right rear abs sensor (the one that always seems to o on audi/vw of any age.) & the bolt that holds the sensor in place has snapped, the head has come off),
now that made it possible for me to remove the dud sensor but leaves me stuck on how to remove the remains of the bolt.
i'm trying to avoid removing the hub & bearing (as that would mean replacing those as well) to drill it out.
but i'm stuck when it comes to tools for the job, i don't have access to an induction heater/hot spanner or a blow torch.
but, i do have a 50W soldering iron, as i saw on the repair shop show (don't ask....) & one of them used the same thing to free off a rusted in bolt on a bit they were working on,
would a soldering iron heat up a 6mm bolt enough to break the bond the rust has made?
has anyone tried this method before??
Any pics Steve please ?
steve_k
not at the moment, i need to get the car back in the air, i'll try to get some tomorrow if i can.
You would need a few KW to get any amount of heat into that, stick it in with some silicone and get back to work on the E30
steve_k
cheers dan sounds like an idea, i've got some tiger seal in the shed
flybynite
As Dan says you will need more than a soldering iron, even on 6mm. I use a small plumbing MAPP blow torch and it works really well, useful for lots of things.steve_k wrote: ↑Tue Jun 06, 2023 5:22 pmbut, i do have a 50W soldering iron, as i saw on the repair shop show (don't ask....) & one of them used the same thing to free off a rusted in bolt on a bit they were working on,
If it falls off with silicone use araldite
steve_k
well to be on the safe side i've got a small mapp blow torch on the way from amazon,flybynite wrote: ↑Wed Jun 07, 2023 8:19 amAs Dan says you will need more than a soldering iron, even on 6mm. I use a small plumbing MAPP blow torch and it works really well, useful for lots of things.steve_k wrote: ↑Tue Jun 06, 2023 5:22 pmbut, i do have a 50W soldering iron, as i saw on the repair shop show (don't ask....) & one of them used the same thing to free off a rusted in bolt on a bit they were working on,
has anyone tried this method before??![]()
If it falls off with silicone use araldite![]()
might even have some jb weld somewhere.
fixedwheelnut
Best way is to dot punch the centre and drill it out with a diamond tip or hard carbide drill bit, apply heat and use an easy out to shift it, or drill it out to size and re-tap the thread.
steve_k
well it looks like i'll be (trying to) drill it out.
after using nearly a can & a half of gas & getting the bolt nice & cherry red it still wouldn't budge.
so time to find the right size hard carbide drill bit & go at it again.
tiger sealing the new sensor in is looking very tempting.
flybynite
Be careful how you use heat, for an outside bit (like a nut) try to get it off when hot. For a bolt you need to heat it and let it cool.steve_k wrote: ↑Fri Jun 09, 2023 9:16 amwell it looks like i'll be (trying to) drill it out.
I give it a bit of heat then cool it with some WD40 and repeat. Heating a bolt cherry red is not that helpful, you just need to break the bond.
Drilling a small hole and banging in a torx bit sometimes works but for a 6mm, I tend to drill and tap out most of the time.
Good luck
steve_k
thanks for that.flybynite wrote: ↑Fri Jun 09, 2023 12:04 pmBe careful how you use heat, for an outside bit (like a nut) try to get it off when hot. For a bolt you need to heat it and let it cool.steve_k wrote: ↑Fri Jun 09, 2023 9:16 amwell it looks like i'll be (trying to) drill it out.
Good luck![]()
thats my idea with the remains of the bolt, heat then cool, if i have to drill it out i'll retap it or failing that a nut & bolt will hold it in place.
Avoid using carbide bits with a hand held drill as they are very brittle.
A normal HSS bit will be fine just keep the revs down and use some WD 40.
steve_k
thanks for the advise mart
I can send you some if you like mate ??
steve_k
really?? thank you that would be a massive help.
thank you.
I would personally MIG weld a nut on the end of the stub - the heat helps work them loose, then it should undo quite easily with a suitable spanner/socket/Mole grips.
Best to work them loose gradually, starting by tightening a bit, then working it in and out until it unscrews easily.
flybynite
Good advice for posterity, but Steve-k passed away last year. Been a bad couple of years for Zone members, all before their time.Speedtouch wrote: ↑Sat Jan 25, 2025 10:07 pmI would personally MIG weld a nut on the end of the stub - the heat helps work them loose, then it should undo quite easily with a suitable spanner/socket/Mole grips.
Indeed, sorry to hear of their passing.
