e30 S62 swap
m-heaven
Post Tue Apr 12, 2011 9:15 pm
let's make them 3 threads shall we?
donor car (the one on the right)
the car on the e30 so far
jevijavi
Post Mon May 16, 2011 9:11 pm
nice...keep us updated!
turk
Post Thu May 19, 2011 10:25 pm
Keep takeing as many pix!!! Veryyy interested in seeing this progress.
Hopefully I will be adding a 4th thread at some point :mad:
What are your plans for ecu?
Good luck!!!
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
turk
Post Tue May 24, 2011 9:09 pm
Any Progress? :?:
Sump Baffles
TrackDays
Ali786
Post Tue Aug 02, 2011 11:41 am
any updates
Blue 1988 320i convertible
m-heaven
Post Mon Oct 15, 2012 8:58 am
Just thought i will update this thread... Gosh it's been a while.
Well the good news is it's almost done, should fire up this week.
bad news is i didn't go with the s62. there are many aspects that had me away from using a BMW engine as a swap but mainly there are no qualified people who can carry this swap successfully arround us here in the middle east.
i ended up going for a 4G63 swap because the shop doing it is very experienced
you can see most of the pictures here.
http://e30m3b-spec.blogspot.com
davethegoat
Post Tue Oct 16, 2012 1:25 am
I was thinking of a 4G63 swap in mine before I went for the S62 funnily enough! It looks good in there, and a lot more room than the V8 :D
What's the engine/turbo spec?
m-heaven
Post Wed Jan 30, 2013 12:17 pm
I went with an evo8 engine, Evo X turbo, and subaru STI gearbox...
the engine sits vein the same location as the S14... i'm speaking from a weight distribution point of view.
e21Jason
Post Wed Feb 06, 2013 4:02 pm
Where is your garage I would like to check it out, and did you get a visit from speed hunters.
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Mikey_Boy
Post Thu Feb 07, 2013 5:54 am
^^^^ Now that is tidy!
Excellent stuff! :thumb:
davethegoat
Post Wed Apr 24, 2013 12:18 am
Is it finished? :D
I just came across this dyno graph from my 4G63. Evo VIII engine with IX turbo, GSC S1 cams on stock cam wheels and 3 inch Magnex full system. It was fun in an Evo. It'll be fantastic in a car with a few hundred less kilos and rear wheel drive I think! :
