E30 M3 S62.........Deja vu?
winx
Post Sat May 08, 2010 4:23 pm
Any more progress Glen?
glenn
Engine Transplant Services
Post Sat May 08, 2010 4:39 pm
winx wrote:Any more progress Glen?
yes mate,
i've been breaking a lot of e36 m3 evo's lately, so they've taken a lot of my spare time.
and then a friend of mine came to have a look at it and said
"i've got to get me one of them", so off he went and bought an e39 m5 to break for his bits. then he twisted my arms for my engine mounts and gearbox mounting. so about four weeks ago i was actually going backwards with this!
since then i've made myself another set of engine mounts, and made another gearbox crossmember. last weekend i finished the exhaust system. my plan for tomorrow is to sort the prop, and then thats most of the stuff done underneath.
no1_jazz
Post Sun May 30, 2010 3:59 pm
top stuff there mate this sure must be a quick car once all is done good luck and all the very best in getting this done
regards
Jazz
glenn
Post Tue Jun 15, 2010 7:50 pm
i thought it was about time i did a little update...............
propshaft on and finished
exhaust on and finished
remote oil filter mounted
i've decided to use the e32 750 hydraulic booster for the brakes.
its mounted and can be activated by the brake pedal, just got to get some pipes made up to finish the brakes.
fitted a new water pump
i've just about finished cutting down the loom, i want to start the engine in-situ before i trim any more off it.
Post Tue Jun 15, 2010 8:16 pm
:cool: :cool:
Dezzy
CR24v it's a lifestyle
Post Tue Jun 15, 2010 8:43 pm
Very :cool: :cool:
glenn
Post Wed Jun 16, 2010 8:19 am
i couldn't find anywhere to put the e32 reservoir, it was just too big.
it was easier for me to find room for two e36 reservoirs. they'll hold almost as much oil. the e32 reservoir holds oil for it's self-levelling suspension, so without that, these should be sufficient.
MrBenn
Post Wed Jun 16, 2010 8:57 am
Good work Glenn :cool:
Dezzy
Post Wed Jun 16, 2010 9:26 am
It really is a top effort this one.
I would love to be able to tackle one of these but defos to mush for me!
@Alex whats the S50M3 like to live with mate :D
MrBenn
Post Wed Jun 16, 2010 9:42 am
Dezzy - Very good fun.......until the fuel pump disconnected and I got towed home by the AA :o:
Dezzy
Post Wed Jun 16, 2010 9:56 am
MrBenn wrote:Dezzy - Very good fun.......until the fuel pump disconnected and I got towed home by the AA :o:
Rubish. :(
Easily sorted though.
Sorry for off topic :D
Frenchguy
Post Mon Jun 21, 2010 12:28 pm
glenn wrote: i've just about finished cutting down the loom, i want to start the engine in-situ before i trim any more off it.
Wiring wise, what "parts" does one need to have from the original car? I guess the engine wiring alone is not sufficient, and that you'd also need -at least- the clocks and its associated wiring?
Thanks and good luck with the rest of the swap (you should be used to it by now:D)!
glenn
Post Mon Jun 21, 2010 7:38 pm
the ecu has five plugs going into it, four from the engine, and one from the 'car loom' .
the car loom plug contains the signals from the 'fly-by-wire-throttle'. other wires on this plug are for the fuel pump and the instrument cluster.
the abs/dsc module is also a big part of the plug, as its looking for 'spinning wheels' via the abs sensors, the rear right wheel being the speed signal for the dsc/ and instrument cluster.
other wires on this plug are for the steering angle sensor, which is on the steering column. also, there is the 'ok' from the ews.
the ecu---instrument cluster---dsc/abs are all linked by the can-bus network
:mad: :mad: :mad: :mad: :mad: :mad: :mad:
glenn
Post Sun Jul 25, 2010 7:24 pm
well............
been putting in some serious hours into this project lately......
two weeks ago, Uwe contacted me to say a friend of his could flash my ecu to work perfectly with just a handful of wires connected, which makes life a whole lot easier for this conversion.
so, through Uwe, the ecu went off to germany, and two weeks later it came back. while it was away, i got stuck in with the other parts that needed doing. the ecu was also installed with alpha-n, so it now runs maf-less, and power is now 440bhp.
a little bit more tidying up to do, with the c101 plug, and i may have to put another silencer in the system. there's no cats on the exhaust, the ecu has had the cat-delete.
i grabbed a quick video of it running, not easy with one hand holding the camera!
thanks for your help Uwe
Dezzy
Post Sun Jul 25, 2010 8:04 pm
That's really :cool:
UweM3
Post Sun Jul 25, 2010 9:08 pm
glenn wrote:well............
Glenn that's good news! So it fired up without any problems.
Can't wait to hear how it drives.
kerrie
Post Sun Jul 25, 2010 9:23 pm
Sounds awesome Glenn, Great job, The brake set-up looks familiar!winkeye :wink:? You won't be disappointed Mine feel better than my E90 BMW brakes.
Cheers.
glenn
Post Sun Jul 25, 2010 9:29 pm
UweM3 wrote: Glenn that's good news! So it fired up without any problems.
i was just finishing off wiring in the fuel pump relay, and thought, i'd better check the oil....smack on the top mark.
finished off the fuel pump relay.......checked the oil again :mad:
filled it with water, checked the oil again :mad:
i dont know what i was thinking, lol.
got the ecu from the house, plugged it in, connected the battery,
turned on the ignition, fuel pump buzzed into life, turned the key to position 3, expecting nothing...but it burst into life.
i let it run for about 10 seconds then turned it off to check for any leaks, no probs.
cranked it up again, running sweet, blipped the throttle......nothing :( ,
switched it off, unplugged the throttle, plugged it back in, re-started it, throttle was fine :D
i started the car around midday, and have been numb with excitement all day
8)
ricey46
Post Sun Jul 25, 2010 10:55 pm
Nice!! winkeye
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
kristov
Post Mon Jul 26, 2010 10:10 pm
kerrie wrote:Sounds awesome Glenn, Great job, The brake set-up looks familiar!winkeye :wink:? You won't be disappointed Mine feel better than my E90 BMW brakes.
Cheers.
What brake set-up are you referring to?
glenn
Post Mon Jul 26, 2010 10:26 pm
e32 750i hydraulic booster set-up.
turk
Post Mon Jul 26, 2010 10:34 pm
Glenn u R A GOD!!! :bow:
I will be up in Brynmawr in a couple of weeks would love to come and have a butchers!
Can I trouble u for that ecu guys details? as im very near to buying an s54, and need similar stuff done im told...
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
kristov
Post Mon Jul 26, 2010 10:39 pm
How is the pedal feel and modulation compared to a vaccum assisted system?
glenn
brynmawr is only 10 mins away.
give me a shout closer to when your coming down.
turk
Post Tue Jul 27, 2010 2:41 pm
Will do mate. Can't wait to see this beast
Sump Baffles
TrackDays
Frenchguy
Post Fri Jul 30, 2010 7:50 pm
glenn wrote: i started the car around midday, and have been numb with excitement all day
8)
I bet you were!
Bravo (as we say here)!
Frenchguy
Post Wed Aug 11, 2010 8:13 pm
Did you retain the ABS system, being that it's no longer needed for the engine to rev at full capability?
Do all the clocks work? Seems like you have the stock instrument panel.
Oh and please share your driving impressions, road kills, etc. !
glenn
Post Wed Aug 11, 2010 8:28 pm
Frenchguy wrote:Did you retain the ABS system, being that it's no longer needed for the engine to rev at full capability?
i didn't keep the abs, as you say its not needed anymore.
all my instruments work, but i've not connected the revcounter yet as i dont have a v8 coding plug to modify yet.
i've not had it on the road yet, as since getting it running, i've been busy with putting a m60 into another e30 for someone else, which is done, and i'm halfway through another s50 into an e30 for someone else.
glenn
Post Sat Sep 18, 2010 5:07 pm
well.....
i finally got the car to 'drivable' standard,
and took it out for a few miles this afternoon... :drool:
it makes a perfect v8 rumble, although i do have a slight 'blow' along the exhaust somewhere, it just makes a 'ticking' sound under heavy load.
i have a small issue with the belt/pulleys....
one pulley was damaged whilst the engine was in the e39, and i hadn't noticed when i was doing the conversion, and it has shredded the outer 2 'vee's',
and so i didn't want to give it too much rpm today as i didn't want to be stranded somewhere, now that i know it will be ok, i'll take it a bit higher tomorrow winkeye
i'll get it changed shortly
the torque is monsterous, even on completly dry roads today, it would easily lose traction in second or third 8)
cant wait to push it a bit further tomorrow :D
FormerMember
Post Sun Sep 19, 2010 1:08 pm
Great! Try to keep it on the road this time.. and make some videos! ;)
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
UweM3
Post Sun Sep 19, 2010 7:31 pm
I am working with a friend on a project of fitting a "modern" ABS instead of the E30 ABS. Can't say too much right now just in case it doesn't work and we make fools of ourselfs winkeye
glenn
Post Thu Sep 23, 2010 8:14 pm
clocked up around 100 miles over the weekend.........the car is brutal !
i'll wait another week to tax it (new month),
sorted the insurance out tonight, all mods declared.
phewwww.............brutal :D 8)
