I've been looking for an 850 clutch without much joy. Sachs don't have a "performance" option as they do for the stock M5 or 840, although they seem to be available in the US from UUC (at a price!). I guess there'd also be import duty and VAT to pay on that too.
I could get hold of a LUK 850 clutch, though I'm not sure whether that would be much better than the Sachs M5 unit.
I thought about using an E34 M5 pressure plate (as Turk suggested) with a helix or similar sprung hub, but the pressure plate is apparently deeper... or complete helix kit, but having more friction area than this would offer would make more sense.
I'm leaning towards the 265mm 840 Sachs performance clutch kit at the moment.... or the LUK 850...
I had a paddle clutch in a road car a few years ago. As you say GermanGorilla, no thanks!
Has anyone had expierience with the LUK stuff? Am I missing any other decent options??
So, back the engine noise.
I fitted a set of vanos seals. I thought I might have been on to something here.
The nearside popped apart no bother. When I took the offside cover off, there were obvious grip marks on the solenoids where someone had been in there before.
It took over half an hour to get the solenoids out, so I was hoping to see some damaged seals. The "O" rings, as on the other bank though, looked to be in decent condition. I checked the cam timing which was good and bolted it back together. Drove it. Unsurprisingly, no change to the noise.
I had the plenum off again looking for air leaks and found the start of a split in one of the ICV hoses, but it hadn't split all the way through, so wasn't a problem either. @rse.
I then had a go at downloading INPA, a diagnosis program. With my special computer skillz, and a marked lack of enthusiasm, I gave up in not a great deal of time.
So this morning, Turk was in the 'hood and bought his laptop along for a short while. The good news is that all the sensors checked out good and the vanos (after clearing a fault code from when I disconnected it) had no faults. The one thing that did show up when driving was the knock sensors are being triggered with even the lightest throttle load.
Luckily, the weather was rubbish today, so I had some time for a bit of reserch.
I reckon that it's a big end. It's reasonably common on S62's, so much so that there are a good few M5 owners replacing big ends as a preventative measure on 100k old engines. There are cases of them failing a good deal earlier too.
I'm guessing that having fresh (and the correct grade) oil was enough to un-mask a previously unseen (or unheard) problem. The knock sensors are quite possibly picking up the big end noise as "knock" and retarding the ignition under any throttle load (which I saw the other day looking at live data on the basic diagnosis program which I have).
Ah well, onwards and upwards!
If anyone wants to fire me a PM telling me that they can get me a massive discount on half a bag of sand's worth or shells and gaskets, now's the time!
Cheers. Dave.
P.S. Sorry for the lack of pics. I've mislaid my lead and my phone memory is full. The world's against me!!
