now i know most will say put a bigger more powerfully motor in but i'm going to stick with the m10 unit.
so the plan is to get hold of another long block and rebuild it.
up the c/r a bit , bigger cam, port the head, 3 angle seats etc and put a pair of 40's on it.
what i'm looking for is any info on who does these parts and any info on tuning the m10 unit.
aiming for about 130bhp so as you can see i dont wnat massive power just enough to make it fun for the road rallies and autotests i do.
tuning
m_jermyn
e21Jason
Best site for info is bmw2002faq
130bhp is easy for an 10, best tring to get a 2.0 bottom end, tunned 2.0l used in historic racing make about 220bhp.
lots of parts around for an idea check the us sites
VAC
Korman
Metric mechanic
Ireland Enginering
VAC
Korman
Metric mechanic
Ireland Enginering
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
toby
I know someone with a 2.0l bottom end they might want to sell if you are interested.
judgie
slight change in plan as the road rallie regs will only let me run a single duel barrel carb so will prob go with a 38dgav, think it has a 32/36 on it now so i'll see what thats like. should still be able to get 130bhp with a single carb?
judgie
as long as its a single twin choke its fine. who dose the single side draft manifolds?
Olie
hate to tag along but i have a m10 and am doing the 2l bottom end conversion, have another block and crank and am now working on the pistons, need a set of m10 2l pistons not flat top or dish, any ideas.
84' Baur convertable 318i - 2ltr turbo stroker in the works
steve_k
Just a thought but have a look on fritz bitz website as there's a fait lump of info regarding tuning the old M10 lump.
could be worth a look.
