Having a clearout, lots of M20 and E30 stuff.
handpaper
Post Sun Feb 28, 2021 4:27 pm
Since my E30 is probably the last I'll own, and is getting less and less standard, it's time to stop hoarding bits I'll never use.
All prices include p&p except where indicated
M20 standard 80A alternator. Good working order, recent new regulator/brush pack. Also comes with that specific shallow-headed mounting bolt. £45.
E30 rear shocks. Used, a bit crusty but still working. Complete with bumpstops and OE BMW gaiters. £20.
Renault Clio brake servo. If you're fitting an M50/52/54 and need more room, this is not the servo for you. It's from a MK1 Clio and it will foul the manifold just like the OE unit. However, if you're just looking for a replacement for your broken OE unit, and you're still running the standard M20, this will do just fine. £15.
More to come, I'll be updating this thread over the next few days.
handpaper
Post Thu Mar 04, 2021 4:32 pm
Built to a design by the legendary UweM3, OE front top mounts modified to be camber-adjustable.
Used on my 325i track car for years, only replaced when I fitted pillow ball mounts to get even lower at the front.
These give around 3 degrees of negative camber with coilovers, less with standard springs as the spring cap fouls the strut tower.
To adjust, slacken the nuts, jack the car up and push the strut in/out, retighten the nuts and lower the car again.
£30 the pair, posted.
handpaper
Post Fri Mar 05, 2021 12:39 am
Heater hose connector, the small casting that bolts to the rear of the cylinder head, 3 available, £10 each.
Thermostat housings. Bleed screws are not seized, neither are thermostat cover bolts. One is from an E34 but should be fine with the correct dash temp sensor. £20 each.
Rocker covers. Grubby but solid. 3 available. First two to sell will come with oil filler caps. £30 each.
Thing that catches (some of the) oil that leaks out of the gearbox bellhousing. BMW call it an 'air duct' but we know better. £25.
handpaper
Post Fri Mar 05, 2021 2:03 am
Two pairs of working headlight wiper motors, £100 per pair.
Wiper arms NOW SOLD
One pair of motors NOW SOLD
I may have more HLWW bits, going to have to rummage deeper...
handpaper
Post Fri Mar 05, 2021 12:28 pm
Dizzy cap and HT leads, complete with cylinder 6 sensor.
These were last used on an engine running LPG and 7 lbs of boost, so they should be pretty good! £40 posted.
