Consolidated E30 Dismantling Thread - 316i to 325i Sport & M3...
£40 + post.
Brigates967
Would you have a rear valance for a 1994 316i touring
Only as a cut from a solid shell but they are still available from the dealer for not a lot.
Brigates967
Ok thanks didn't know that ,how much is a cut anyway ?
£45 inc. post.
£200 inc. delivery.
A cut would get you a bit of depth, i.e. the inner panels of the rear as well, as opposed to the single pressed sheet of the outer valance which is what you get when buying new. But if you only need the outer or lower piece of the valance, buy the new one, it should be less than £200 all in from the dealer.
E30 stock list updated, as well as the entire stock list:
Current stock (kept updated):
1971 E8 Neue Klasse 1800 manual
1974 E8 Neue Klasse 2000 manual
1974 E10 2002 manual
1977 E21 316 manual
1982 E21 320 auto
1983 E24 635csi manual
1989 E24 635csi Highline auto
1985 E28 M535i manual
1986 E28 528i auto
1987 E28 518i manual
1987 E28 520i manual
1987 E28 528i auto
1987 E28 528i auto
1985 E30 325i Saloon manual
1985 E30 325i Alpina manual
1986 316 Saloon manual
1986 325i Sport manual
1987 325i Sport manual
1988 316i Coupe auto
1990 325i Saloon auto
1990 325i Coupe manual
1990 325i Convertible manual
1990 325i Sport manual
1991 318i Touring auto
1991 320i Coupe manual
1991 320i Convertible manual
1994 E31 840ci manual
1989 E32 750iL auto
1990 E32 735i manual
1989 E34 525i manual
1989 E34 535i manual
1990 E34 M5 3.6 manual
1993 E34 518i manual
1993 E34 520i manual
1993 E34 525tds auto
1994 E34 518i manual
1994 E34 525i manual
1994 E34 530i manual
1995 E34 518i manual
1995 E34 520i manual
1995 E34 525i Sport manual
1996 E34 520i Touring manual
1993 E36 325i Cabriolet auto
1994 E36 320i Saloon manual
1994 E36 M3 3.0 Coupe manual
1994 E36 M3 3.0 Cabriolet manual
1995 E36 325i Cabriolet manual
1995 E36 318i Saloon manual
1995 E36 328i Coupe manual
1996 E36 318i Saloon manual
1997 E36 323i Cabriolet manual
1997 E36 328i Touring auto
1998 E36 323i Sport Touring auto
1998 E36 328i Cabriolet manual
1998 E36 328i Sport Coupe manual
1999 E36 318i Sport Cabriolet manual
1999 E36 M3 Evo Cabriolet manual
1996 E38 728i auto
1997 E38 728i auto
1998 E38 750iL auto
2000 E38 728i auto
1998 E39 528i auto
1998 E39 528i Touring manual
2000 E39 528i Touring auto
2000 E39 528i Sport auto
2000 E39 530d manual
2000 E39 M5 manual
2001 E39 530d manual
2001 E39 530d Sport auto
2002 E39 525i manual
2002 E39 525i Touring manual
2002 E39 525i Sport auto
2002 E39 530i Sport auto
2003 E39 530d manual
2003 E39 530d Touring manual
1998 E46 318ci Coupe manual
1998 E46 320i manual
1998 E46 328i auto
1999 E46 320d manual
2000 E46 330ci Cabriolet manual
2001 E46 318ci manual
2001 E46 320i Touring auto
2001 E46 320d Touring manual
2001 E46 325ci Sport Cabriolet manual
2001 E46 330d Aero manual
2002 E46 316ti Compact manual
2002 E46 318ti Compact manual
2002 E46 318i manual
2002 E46 318ci Coupe auto
2002 E46 320d manual
2002 E46 320d Sport manual
2002 E46 330d Sport auto
2002 E46 330d Sport manual
2002 E46 330i auto
2002 E46 330i Sport auto
2002 E46 330ci Sport Cabriolet auto
2003 E46 318ci Sport Cabriolet manual
2004 E46 320d Sport Individual manual
2004 E46 330d Sport manual
2005 E46 318i Touring Sport Individual auto
2005 E46 320d ES manual
2000 E53 X5 4.4 auto
2001 E53 X5 3.0 Sport manual
2002 E53 X5 3.0d Sport auto
2004 E53 X5 3.0 Sport auto
2003 E60 525d manual
2003 E60 530d manual
2004 E60 530d manual
2002 E65 745i auto
2004 E87 116i manual
2006 E90 318i manual
2002 R50 Mini One 1.6 manual
2003 R53 Mini Cooper S manual
1977 E21 316 manual
1982 E21 320 auto
1986 E28 528i auto
1987 E28 528i auto
1987 E28 528i auto
1989 E32 750iL auto
1996 E38 728i auto
1997 E38 728i auto
1998 E38 750iL auto
2000 E38 728i auto
1998 E39 528i auto
2000 E39 M5 manual
1998 E46 328i auto
2002 E46 330i auto
2002 E65 745i auto
- MyNameIsOllie
How much for 51mm front struts with or without brakes?
Also, how much are rear disc brake trailing arms with calipers etc.?
- boiliebasher
I'm after a m20b25 touring coolant radiator fan shroud and all the bits that go with it.
How much inc delivery to Hampshire please?
With or without ABS on both counts?MyNameIsOllie wrote: ↑Fri Aug 30, 2019 11:14 amHow much for 51mm front struts with or without brakes?
all gone now sorry.boiliebasher wrote: ↑Sat Aug 31, 2019 11:07 amI'm after a m20b25 touring coolant radiator fan shroud and all the bits that go with it.
- MyNameIsOllie
Withoutsskoda wrote: ↑Mon Sep 02, 2019 11:34 amWith or without ABS on both counts?MyNameIsOllie wrote: ↑Fri Aug 30, 2019 11:14 amHow much for 51mm front struts with or without brakes?
Yep, £75 apiece.
Circa £250 for something with just one or two small cracks. We can get photos if you want.
Front strut bodies non-abs without brakes £150 deliveredMyNameIsOllie wrote: ↑Mon Sep 02, 2019 1:10 pmWithoutsskoda wrote: ↑Mon Sep 02, 2019 11:34 amWith or without ABS on both counts?MyNameIsOllie wrote: ↑Fri Aug 30, 2019 11:14 amHow much for 51mm front struts with or without brakes?
Rear arms without brakes non-ABS £150 delivered
Brakes + £50 front, + £30 rear.
- MyNameIsOllie
Thanks for the reply. I'll consider this when I sort out my suspension.sskoda wrote: ↑Wed Sep 04, 2019 4:11 pmFront strut bodies non-abs without brakes £150 delivered
- boiliebasher
After a decent throttle cable for a 1989 325i touring please with all gubbins etc. Must be in good condition/ working order please. Many thanks.
Yes to this (PM us)
But no to this. Sorry.boiliebasher wrote: ↑Sun Sep 08, 2019 8:44 pmAfter a decent throttle cable for a 1989 325i touring please with all gubbins etc. Must be in good condition/ working order please. Many thanks.
We've none cut out right now (nor available shell to cut up at the minute).
- boiliebasher
Is the tail gate for the e30 touring you have in stock any good?! Cheers
- Caravanking
Any m42 intake manifolds and throttle bodies? And how much please?
All the good ones are gone already sorry.boiliebasher wrote: ↑Mon Sep 23, 2019 4:05 amIs the tail gate for the e30 touring you have in stock any good?! Cheers
All gone now.Caravanking wrote: ↑Mon Sep 23, 2019 9:17 pmAny m42 intake manifolds and throttle bodies? And how much please?
None available.
