Thanks! I'll check once more the rev limit since I was not winding it up, because of the AFM "doing it's thing" at around 5,000 rpm.. Also need to confirm the ECU number, then can I open it and maybe see the chip for any clues. Also injectors need cleaning, as well as AFM to be replaced, which will all be fixed in a couple of days. I'll send you a PM afterwards. Either way, I am leaning towards trying another chip and comparing, since I don't trust much local tuners here and their approach.Speedtouch wrote: ↑Mon Sep 06, 2021 5:11 pmWelcome to the Zone! If yours has a rev limit of 6.500rpm, it probably has been re-mapped, since stock rev limit is 6,250rpm. I can supply a chip to suit if required...Voockey wrote: ↑Sun Sep 05, 2021 12:29 pmHi, I am new member, my first postGot hold of a nice E34 with a M20B28 rebuilt 53tkm ago, need to investigate whether it was mapped. My impressions are that it's not mapped (also rev limit 6.5) and perhaps even the cam is left stock. Planning later to put this engine in my E30. While it's running in E34 I want to check it completely and make it better (injectors need to be cleaned, AFM checked).
Will the M20B27 chip suit my 2.8l engine? Injectors stock, tubular headers, decat + free flow exhaust (lovely sound), stock B25 AFM... cam - need to check, but idle is as stock, so it is either stock cam, or mild cam..
ECU EPROM Upgrade Chips Sale
PM sent.
PM sent.
- Acox99
Can I ask why the ecotorque has such a high Rev limit compared to the wild/alpina chips?
I have a 1989 chrome bumper 325i which is in storage. Do you need my ecu number still?
1989 E30 325i cab - long term project!
Yes, if you can provide your ECU number; it should be 173 or 380...
PM sent.
Your latest message to me is "on hold" for some reason, and I can't read it - please e-mail me instead.
Hey... just picked up a 0 261 200 172 ECU for my 320i auto (upgraded from the Motronic 1.1 152 which i messaged you about before) so I'm in a position to order a mild chip now please. Email is will_meyer@hotmail.com
Cheers!
Cheers!
Thanks again, Will.
PM sent.
- fixedwheelnut
I have PM'd you about a chip for my M30 b3.5 engine.
Steve
Steve
Sorry, I don't have any chips for the M40B18.
TBH, it probably wouldn't make a noticeable difference on a 1.8 automatic...
Any sales going on atm
Maybe, come the Summer Bank Holiday...
Put me down for a for a mild B20 please
Hello,
Interested in the following one:
3. For early chrome bumper 325i/Tech 1 Sport with 073 ECU, 8-10bhp gain, 6500rpm rev limit.
Could you please send me the details to the following email: fcampeloarribas@gmail.com
Any risks? Engine durability?
Compatible with a 272/272 camshaft? Need to install a new exhaust manifold?
Thanks in advance.
Thanks in advance.
PM/e-mails sent.
PM sent.
MattTouring325i
Just sent you a PM for the Ecotorq M20B25 Mild Chip. Should be a good improvement on my 90 325i Touring Automatic.
PM sent.
Hello, the chip arrived an hour ago, swaped the chip and ecu (i have a secondary dme just for it). The car was still hot from a small trip this morning and it started right away like normal however on the first few meter i could notice the difference in low rpm range torque.
Couldnt drive more at higher speed but i can already from a 10km trip, tell the car feel for "aggressive" or powerfull? (dont know how to call it in english), more responsive at every rpm range. Can also notice the engine has a bit changed it sound to something slightly more sexier (well i'm talking of a 100% stock e34 m20b20 so nothing very fancy right)
Thanks for this m20 revival
Fast delivery, very good communication, dont hesitate to get one yourself, your m20 deserve it and will thanks you.
PM sent
PM replied to.
BTT.
Hi,
Sorry for the delayed response (been very busy with work, fixing other people's cars). They are quite easy to fit - see the Zone Chip Fitting Guide:
https://www.e30zone.net/e30wiki/index.p ... ting_Guide
They work by altering the fuelling map and ignition timing, for a more optimised state of tune.
