Hi there.
So I am looking at the V8 conversion, I am looking to go down the AUTO box route (yeah yeah I know i know...)
I was informed I need to get the ABS system from the donar car, but I am wondering if there is any other way around it to make the autobox work?
Thanks!
M62 with auto box
You could probably get an emulator or signal converter, but essentially all you need to do is generate the correct rotating signal for the ABS unit and then wire that to the transmission ECU, no need for the hydraulic part of the system
