Does anyone have any pictures of their M60 manifolds after modification to fit into a UK RHD E30?
I can find plenty of LHD pics which look like they have mainly altered the downpipes where they run alongside the gearbox, but I'm keen to see what's required around the steering shaft.
Pics of RHD exhaust manifolds for M60 E30 V8
V8turd
I know that x5 manifolds can be modified to fit but I chose to have a pair made up custom. I just used the standard ones for their flanges so and had the primaries welded to those so they fit the head
I know this is not much help and I don't know how to upload pics using my phone to show you mine but I found it the best way to go really having looked at how restrictive standard manifolds are
If I can figure out how to u0load pics I can show you what mine look like
Ant
Ant
seikais
Hello, i got on my e30 m62b44 from 7 series. Left hand used stock with small modifications and right hand used from x5 v8 3.5 with loads of cutting and welding. ( the section with lamda zonds stock with some cutting and welding as well).
