m62b44 non vanos loom
sidewaysbm
Post Wed Sep 02, 2015 8:42 pm
Im considering putting a non vanos m62 in my e30 and was wondering is it possible to connect an m60 404 ecu to the m62 engine loom? also are m60 engine looms and 404 ecu's hard got? thanks
sidewaysbm
Post Mon Oct 26, 2015 1:36 pm
bump
Post Mon Oct 26, 2015 1:47 pm
Why would you want to? The management that the engine runs on perfectly would be the obvious choice for me
sidewaysbm
Post Thu Oct 29, 2015 1:31 pm
Its just that i heard the 404 doesnt have ews so i was wondering could i connect it to my m62 loom or would i need an m60 loom. I obviously would need to remap it after because of the extra capacity so it may be more hassle than its worth.
Post Thu Oct 29, 2015 7:11 pm
Its defo more hassle than its worth, EWS is pretty simple to wire up and get working as intended
padi
Post Wed Nov 04, 2015 2:04 pm
It can be done, but you need the full m60 loom and sensors etc as well as the ecu. Search for m60b44 as that's almost what you would have.
To be honest it'd be easier to deal with the ews which is easy if you have the chip and antenna etc.
Cheers Chris.
seikais
Post Mon Jul 04, 2016 9:37 pm
is there any diagrams guys to do this EWS and to connect m62b44 loom to e30 connector? thanks :(
Post Mon Jul 04, 2016 10:54 pm
WDS is your friend
seikais
Post Tue Sep 06, 2016 8:08 pm
DanThe wrote:WDS is your friend
thanks mate, running now :) :
Post Tue Sep 06, 2016 9:11 pm
Good to hear, nice wire nest :) EWS fitted?
seikais
Post Tue Sep 06, 2016 9:52 pm
DanThe wrote:Good to hear, nice wire nest :) EWS fitted?
:D EWS deleted :P
Post Tue Sep 06, 2016 10:06 pm
Good luck with that :)
