Hi
I've got an 89 325 with an m60b40 and the one niggly thing is the oil level on the check panel is always lit up so i have to push the check button, i've tried to search about to find a solution but can't seem to find anything, maybe i'm looking in the wrong place or there is no fix?
i tried connecting the wires between the m60 socket and the c101 that are listed for static and dynamic oil level but neither make the light go out.
Anyone managed to work this out?
thanks Paul
Oil level check panel connecting/bypassing
pau1us
andy179
Hi did this a year ago now, cannot remember what size, but involved using a resistor across it, think I found the spec of the sensor somewhere as aguide, straight to earth will not work, drove me nuts
