currently in process of taking a 4.4 out of a 97 e38
i was planning on a ews del on the ecu
do i still need to retain the ews box and key from donor car?
any help appreciated
cheers
m62 out of e38
As far as I know most people offering 'EWS delete' services on these are actually just fitting an EWS emulator, so the EWS is not actually deleted. Therefore the EWS module and chip can still be used if the emulator is removed
GB69
Can use an M60 404 non EWS ECU, and M60 loom. Need to weld a bracket to the engine for M60 crank sensor, and get ECU mapped/chipped to take advantage of extra .4 litre.
leeparkes
Cant you just use the EWS bits? Module, key chip etc...
ajazyasin
how is it possible to tell if the m60 ecu is non ews?
ta
ta
GB69
404 ECU is a non EWS, 484 is EWS.ajazyasin wrote:how is it possible to tell if the m60 ecu is non ews?
ta
