m62 oil lamp wiring.
norfy
Post Thu Apr 04, 2013 6:41 pm
Hey there just after a quick bit of info about wiring up an oil warning lamp.
Ive got a nissan sil80 that ive transplanted a m62 from a 840ci, its 99% done but ive got a couple of issues that need ironing out, one of which is getting a working oil warning lamp.
Unfortunately some tit didn't leave the wiring in for the stock oil pressure switch :roll: and I don't have the stock oil filter housing anymore anyway lol
So im wiring the lamp up to the high/low level sensor on the sump (would be nice to know if it dumps its oil). Ive got three wires, one brown for earth, one blue/white and one blue yellow which ive wired in to but the warning lamp is on constantly.
See im not sure which wire is for low level. I might have the right wire but a dud sensor? Thought id ask which wire is low level
FormerMember
Post Sun Apr 07, 2013 8:53 pm
It has two circuits - one for "power on" and another one for "ignition on / engine running".
WDS will tell you how it works, try putting "BMW wiring diagram system" on google and you'll find plenty of options ;)
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
