has anyone seen any conversions with this bad boy power plant?
i believe its from either a 550i, 650i, 750i or X5.
buckets of torque like almost 500lb-ft and 360bhp
N62b48........ light bulb
Driftben
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
FormerMember
Yea, but Valvetronic & double VANOS combined with all the DSC, EWS 3 etc etc hassle has driven people using M60-variants that give out - not exactly same but quite near - power / performance figures
M60B49 is doable (M62B46 block, S62 crank, custom pistons) and with slightly modded heads would give 400hp / 500Nm, combine that with M62TU VANOS heads and you're quite close already (and you don't have valvetronic causing headaches).
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
