m60 no spark
sparkyE30
just fitted an m60b40 today and it isnt getting a spark.checked all the earth tags are attached.all the live wires are attached.double checked everything is plugged in.used the wiring diagram to join the c101 plug to the x20 plug.joined the yellow and black wires going to the autp ecu plug.car turns over fine but no spark.anybody help.cheerz Mark
sparkyE30
found out the problem.my engine has the ews ecu.going to get a non ews ecu and give it a try that should do the trick
