Hi All,
This maybe a dumb question... but, for the aftermarket fan, how did you wire it up?
I have read about using a manual switch, but I would like it to switch by temp.
Rob
Fan wiring
jmc330i
The search function can be your friend.... http://www.e30zone.net/modules.php?name ... fan+wiring
Scroll down to the first post by ian332isport (the long post about 4th from bottom). Its a very detailed explanation of how to wire it up.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
RobF
Thanks James! You have no idea how many searches I did here, on other forums and Google. Its just a case of using the right words!
jmc330i
No worries
The search function does take a little getting used to, but its pretty good once you figure it out.
James
'91 325i Sport
'91 325i Sport
Thats the best fan circuit description on here and should be stickied or wikied
steve_k
+1 got to agree there.DanThe wrote:Thats the best fan circuit description on here and should be stickied or wikied
it helped me out no end when I did mine & I also installed a dash mounted switch just incase
