4.4 to replace my 4.0
Phill172
Post Sat Jun 16, 2012 11:29 pm
Straight swap? Understand more then likely sitting it in mounts, pipe work, exhaust maybe will be all the same but what about the wiring?
Can I plug my 4.0 loom straight in?
Any gains? My 4.0 could do with a light rebuild on the head ( slight blue smoke overrun), so my thought is to not bother and simply swap to a 4.4, maybe do a slight bit of head work before it goes in,
Non vanos units a better option? If there are any!
FormerMember
Post Mon Jun 18, 2012 2:22 am
M62 is different in electronics etc, so not a straight swap.
What you could do is to swap B44 bottom end to B40, this way you would have the best heads, sharpest cams and twinrowchain. Quite a lot of info on that on r3vlimited.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
Phill172
Post Mon Jun 18, 2012 8:25 am
Thanks very much jonsku!
gazza72
Post Thu Oct 18, 2012 6:18 pm
Phil it's Garry from raw Motorsport robin said phone him in regards to this !
