hydraulic braking system ???
cruizin4dirty1s
Tue May 29, 2012 8:01 pm
hi guys started my e30 m60 build today i have the engine about a year just needed some motivation :). anyway just wondering is there any guide to using the hydraulic brake system from the 540i e34 this is the setup i have. or any pictures or info on how the brake setup behind the brakle booster was changed . any help would be greatly appreciated
cheers
owen
Jonsku
Tue May 29, 2012 8:04 pm
The e34 booster is not really hydraulic, but a conventional vacuum-booster.
There's lots of info on different brake-booster approaches on this forum, as well as on www.r3vlimited.com
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
cruizin4dirty1s
Tue May 29, 2012 8:07 pm
well there is a hydraulic system also which is worked from the power steering pump this is the system that was in my e34 540
glenn
Engine Transplant Services
Tue May 29, 2012 9:02 pm
Jonsku wrote:The e34 booster is not really hydraulic, but a conventional vacuum-booster.
some of the v8 e34's had the hydraulic boosters.
i used the hydraulic booster set-up on my last s62 swap
phi1
Tue May 29, 2012 9:48 pm
I have used it and it works great!
cruizin4dirty1s
Tue May 29, 2012 11:19 pm
phi1 wrote:I have used it and it works great!
questions i have mainly are how far did you move it over i was thinking of using the 2 holes already there nearest fuse box and drilling two more and the big one obviously but not sure is that far enough ?
and secondly what way did you work it inside the car did you move the the brake linkage over and extend the brake rod from the drivers side or did you leave that in place and extend the linkage to meet the master cylinder ? any pictures of it ?
Jonsku
Wed May 30, 2012 4:21 pm
Seems that there's always something new to learn every day :)
Anyways, hydraulic brake boosters have been fitted also many times on V8 e30's. Couple of projects can be found also on www.e30.de
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
cruizin4dirty1s
Wed May 30, 2012 10:09 pm
thanks jonsku but they dont really work as the setup would be different due to them being left hand drive .
anyone able to help ?
cruizin4dirty1s
Wed Aug 08, 2012 8:14 pm
still stuck with this i moved the brake booster over but havent figured out how to connect the linkages up inside the car
cruizin4dirty1s
Thu Aug 09, 2012 9:41 am
cool will go at it today cheers
padi
Thu Nov 29, 2012 7:35 pm
Hi guys, I'm just about to order some mounts from 300mm.de mounts, I'm thinking long term ill try and fit an s62,but currently thinking an m60. So question is, is it worth getting the 10mm spacer or 20mm spacers?
Any advice would be great.
Cheers Chris.
PiLLLe
Sat Dec 01, 2012 3:57 pm
It all depends on your ride height. If you have a low setup you might end up with crapy suspension and crapy handling...
padi
Sat Dec 01, 2012 4:32 pm
I'll be looking for around standard to 30mm max! It's running e30 m3 suspension, with eibach springs and Boge shocks. More a comfortable quick cruiser than an out and out race car.
Cheers Chris.
