Mileage wiring?
phi1
Post Wed Apr 18, 2012 4:22 pm
Hi there just finnishing my m60 swap and on the test drives my mileage doesnt seem to go up on the clock so I am guessing I am missing a wire somewhere? Also what wire do I need to put in for the inspection light reset to work?
Cheers Phil
FormerMember
Post Fri Apr 20, 2012 4:47 am
Have you touched the instrument cluster wiring during the swap?
As such, only thing you need to get from instrument cluster is the speed signal, that can be taken from OBC-output. And then there's the rpm-signal, which is an input from ECU to instrument cluster.
But other than that, it's hard to imagine how M60 could affect on that kind of problem..
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
