Guys there is 2 temperature sensors on the drivers side,behind the block
I know you need to change 1 of them to swap over with the e30 brown sensor one but which one?
Temperature gauge sensor
SHAZ325iSPORT
SHAZ325iSPORT
SHAZ325iSPORT
The outer one is for ECU, and that you should not touch.
The inner one is for instrument cluster, and that one you should swap to one that is suitable for your instrument cluster (1 or 2 wire, depending on exact model).
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
- ross5turbo
I can't find a brown one
Any of you lot know what car it's from?
Cheeeeeers Rosco
Cheeeeeers Rosco
- ross5turbo
Okay cheers dude I'll have a look
