Lamba/02 sensors
Darrenr
Post Sun Mar 11, 2012 10:01 am
hi ive been using my E30 m60b40 with e36 sensors for a few months now but i think it maybe over fueling ive been told they should be ok but just wanted to check also the colours where different on the e36 sensors
thanks
FormerMember
Post Tue Mar 13, 2012 5:59 am
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
e301988325i
Post Tue Mar 13, 2012 7:12 am
I don't know for a fact but I'm very sure all BMW's use the 0-1v type of lambda, if it's running rich then it's time to check the blue(?) engine temp sensor and then read the fault codes for the lambdas and check they are switching 0-1v under running conditions.
I said:
e30topless said:
lock the wife in there
Darrenr
Post Tue Mar 13, 2012 3:15 pm
Im running a 1 wire e30 2.5 sensor so that a i get a temp display on dash i wonder if this is causing problems
e301988325i
Post Tue Mar 13, 2012 6:11 pm
Stock E30's have two sensors, one brown for the instrument cluster and one blue for the engine ECU which fails regularly.
I said:
Darrenr
Post Tue Mar 13, 2012 7:48 pm
i dont know if they are working correctly or not tho really, e36 sensors have differnet colours to m60b40 so maybe they aint matched up right
