What rubber mounts?
phi1
Tue Feb 14, 2012 11:20 pm
Hi there, I mounted the engine in the car today and found that the e30 mounts were to small and the engine was hitting on the subframe but only by a tiny bit. What other options do I have?
Cheers Phil
Jonsku
Wed Feb 15, 2012 7:59 am
I've 300mm.de engine arms with E34 V8 rubbers. That combination doesn't clear the steering rack & support (LHS has to be modified slightly) so you need to put e.g. 3-5mm spacers in there.
There's plenty of room in the "bolts" for spacers so no worries, only problem is the engine coming "too high" (touching the bonnet) at some stage..
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
phi1
Thu Feb 16, 2012 3:33 pm
Cheers for the replys, it looks like i am going to be using E34 540I mounts.
