M60 Help needed(wiring)
SHAZ325iSPORT
Post Wed Jan 04, 2012 7:58 pm
guys i have a auto loom which came out of a E32 740i along with the engine.
i want to chop off the auto side off the loom,does anybody have a diagram of what wire exactly i need to chop off?
thanks.
FormerMember
Post Wed Jan 04, 2012 8:45 pm
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
Driftben
Post Thu Jan 05, 2012 8:44 pm
Basicly, everything coming from the auto main ecu plug can be traced through and cut out. You will have quite a few wires going to common soldered blocks which can be cut away. There is one black wire which has a black and a yellow core inside, this can be cut close from the auto ecu plug. (if I'm right these are the 2 cores which need to be joined to fool the main ecu thinking its in gear to raise the idle)
That's Basicly what I have done so correct me if I'm wrong or have missed anything? :wink:
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
