M60 auto to manual swap?
pel
Tue Aug 23, 2011 9:39 pm
Hey, iv finally got myself another E30 after wanting another for a few years, its been stripped out and ill be starting to repair and rebuild it over the next year or so, im thinking of fitting an M60 engine but its hard to find a manual one so was wondering if anyone knows if its possible to convert an auto engine to manual? would really appreciate any help. thanks for looking guys. Perrie.
Jonsku
Wed Aug 24, 2011 7:35 am
Yes its' possible. All you need is the gearbox, flywheel + clutch. The ECU's are the same, as well as most of the wiring. Just cut away all wires related to autobox and then you need to do some additional wiring (so that the ECU thinks that the gear is always at "P" in order to start the engine).
Pretty straightforward, but involves a lot of wiring-schematic reading.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
pel
Wed Aug 24, 2011 8:47 pm
Thats great thanks for your reply, ill definitely be looking into this. all depends how hard it is to find a manual box ill bet their not to cheap!!
200272
Thu Aug 25, 2011 12:44 am
I have a spare 5 spd but all the mount have had it :( , so you'd need to make something up using the casing bolts.
Driftben
Thu Sep 01, 2011 5:57 pm
have yourself a long look at ebay and the 5 series forums mate, your best bet is to buy a cheap 540i. sometimes they come with a manual box where they wanted to convert from auto to manual themselves? i got a 6speed with mine winkeye
good luck dude
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
