Is the same ECU used for manual and automatic M60B40's?
I have an engine and ECU from an auto car and a gearbox and loom from a manual car. Can I use the ECU from the auto car?
M60 ECU's
e30mtech
did you find an answer mate mind i still got the ecu here as well if you do need it.
adam
adam
chips
- Was Pzero
Cheers Adam. I haven't found out yet. Although I'm pretty sure it's just a case of jumping the pins for the connection to the autobox that tell the ECU not to start the car if the auto box is not in neutral. Also there must be differences between the 3.0 and 4.0 ECU's.
chips
- Was Pzero
Can anyone confirm this?
FormerMember
Yea the ECU's are the same, also in B30's. The chips are a bit different, though I'm not sure if that really matters as the pin-outs are exactly the same in all of them.
Maybe someone has researched this further?
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
