got an m60 4.0v8 with a 6 speed box what route is best taken for a propshaft .
is there a direct fit one
or will it have to be custom and any info/pics
cheers
owen
propshaft question
FormerMember
No direct fit, as suitable propshaft behind 6-speeder is from E34 / E32 / E39 / E38 and they have the CV joint in the rear of the shaft and no splined joint in the middle.
The way i went with this was that i used E30 rear part (same diameter as in e.g. E39 M5), E34 540 front part and local shop joined them together with a splined joint from an MB.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
littlechef
do you know if the m62 auto prop is ideal for the chop? I can not find a manual one to complete mine? when you say MB splined joint is it not possible to do this with just the e30/e39 unit?
FormerMember
E39 / E32 / E34 / Ewhatever (V8 engines): http://bmwfans.info/parts/catalog/E39/S ... ity_joint/
E30: http://bmwfans.info/parts/catalog/E30/2 ... vel_joint/
BMWFans tells you which cars have the big "hardyscheibe" / front mesh on the propshaft.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
E30SPDFRK
Heres mine. I used the front of an e32 740i auto shaft and had it welded to the splines and u-joint from a 89 325i. It bolts up like stock and is holding up great.
-Byron
200272
Im just getting the gearbox flange grafted on to the front of a 325i prop.
