I'm in the process of rewiring my M60 (originally from a 1995 E38) with an engine harness from a 93 530i M60. I'm stuck with the alternator connector X6524 on the E38.
X6524
bl - cluster (through pin 15)
gn - fuse F22
open
I want to keep the E38 alternator therefore I need to splice X6524 into the 530 harness (if possible).
Can someone help with the two pins on the 530 harness, what are the two wires for I can't figure it out from the diagram.
