help needed again
stbaz
Post Sat Sep 11, 2010 11:43 am
im using the table on e30.de for the wiring connections for m60 to e30 loom
im stuck with two of the pins as of where they go to
pin 12 e34 to pin ?? e30
pin 14 e34 to pin b12 e30
i cant find a b12 pin in the e30 connector and also cant see on the table where e34 pin 12 goes to.
can anyone help me out please?
baz
FormerMember
Post Mon Sep 13, 2010 8:52 am
You can find the answers here; http://www.e38.org/e34/e34_94_etm.pdf
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
stbaz
Post Mon Sep 13, 2010 6:51 pm
does anyone thats done the conversion have a direct answer for me??
; http://www.e38.org/e34/e34_94_etm.pdf is alot of info but will take me months to trawl through that!!!
FormerMember
Post Tue Sep 14, 2010 5:56 am
The pinouts change from year to year so you'll have to check them out all by yourself. That way you gain also knowledge how the thing works... It's not all "plug'n'play".
Anyways, here's the pinout table from my swap; http://users.tkk.fi/~jhaukile/ETC/C101_X20.pdf
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Gunni
Post Sun Sep 19, 2010 12:25 pm
Black in the C101 round connector is ALWAYS tacho.
Black yellow is always starter
Green is always 12v swithed
Blue is always alternator
When you have done as many engine swaps as me you´ll remember the colors automatically ;)
Gunni
@ 2012 VEMS group buy !!
FormerMember
Post Sun Sep 19, 2010 1:07 pm
Gunni wrote:Black in the C101 round connector is ALWAYS tacho.
Yes, and puprle-red is petrol pump etc etc.. basic stuff ;)
The main colours are always the same but the pinouts change from year to year. Not necessarily the "main function" pins but it's not worth risking as checking the pins out is a 5min job.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
stbaz
Post Sun Sep 19, 2010 1:50 pm
superb mate. thanks for that. 8)
