Just though id stick this up here as it may help a few people out. we had a lot of trouble finding acurate dimensions for the m60/62 engine so now we have our m60 im going to put any dimensions we take up on here so others can find them.
atm we have
height :~24" 610mm sump to manifold top
width: ~27.5" 700mm head to head
length: gearbox face to head front ~24" 610mm
add ~6" 150mm for the pulleys and fan on the front.
M60 Dimensions
HairyScreech
FormerMember
When you're at it you should measure the distance to the top of the throttle-body / engine cover. That's where the hood will touch if the engine sits too high.
Btw, what's the width of E30 frame rails? In my opinion M60 won't come through if one would like to drop it on to floor but not sure..
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
HairyScreech
ill have a measure when im next down the unit.
E30-830
Would the M60 dimensions be the same as the M62??
FormerMember
Yes they are. S62 is also very similar, but it's height is bigger than in M60 / M62 due to ITB's / air box.E30-830 wrote:Would the M60 dimensions be the same as the M62??
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Driftben
i dont suppose you know the weight of the M60/M62 do you?
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
FormerMember
STiBen wrote:i dont suppose you know the weight of the M60/M62 do you?
212kg, the engine without any ancillaries nor gearbox is 142kg.
You can check all the weights at www.bmwfans.info ;)
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Driftben
Good info that. Thanks
6pot wilwoods front
4pot Porsche rear
