Brake linkage: Done
I pretty much completely redesigned the brake linkage so it wouldn't bind up/bend again. I attribute the bending to the heim joint binding up on the bolt head where it attached to the pedal. I moved the mounting location for it to the center of the pedal rather than the outside. I used washers as spacers at first but they would bind too so I switched it up to 3/8" tubing.
This made it not fit through the existing hole in the firewall, so I made a new one.
Then it hit the strut tower support, so I cut that out. I've got a plate made up to bring back the strength, I just haven't welded it in yet.
Rather than the rig I had going before with another heim, the slotted flat bar with the centering pin, and the mismatch of old parts, I just beat down the end of the rod (switched to 1/2" rod too) and fit it directly to the booster. Drilled a second hole so it wouldn't flex.
And the whole setup
I had my boss watch while I stomped on it as hard as I could and it doesn't flex at all. Quite happy with this setup now.
Then I turned my attention to the cooling block and the heatercore. Not once in my research did I hear anyone say how much of a pain in the ass this was haha. I spent all day sunday working on this.
It started with plugging the nipples for the automatic transmission cooler. Cant really see them too well in this pic
Then the heatercore inlet
Then this beautiful contraption for the heatercore outlet/overflow tank
Then I got bored with taking pictures so the rest is all words haha. Mounted the firewall overflow and went to connect it, but the plastic nipple broke off. So I rushed home and got a spare I had laying around so I could get it all bled before I had to leave. Did that and this one started leaking out of the same nipple :facepalm. Went to shut the hood and pull it outside, and the overflow wouldn't fit* :doublefacepalm. Probably should have checked that first lol. So now cooling system plan B has failed too. Plan C is to either make my own overflow out of some sheetmetal, or to run a 325e coolant bottle over where the battery tray was.
It's so close! It's killing me to not be able to drive it even though it runs haha.
* You were right Jonsku
