My M62B44 build
chu346
Sat Apr 16, 2016 3:13 pm
I'm considering using the entire e39 wiring loom, sensors, the lot.
Is there any reason why I shouldn't?
Sat Apr 16, 2016 7:56 pm
because you don't need to, is a pretty good reason IMO
chu346
Sat Apr 16, 2016 9:49 pm
Seeing as I need the clocks and abs sensor. I wouldn't mind dsc and abs system, so is it still not worth it?
Sun Apr 17, 2016 10:26 am
You don't need the clocks! :D
If your dead set on the ABS just get some Mk60 bits from an E46, doesn't have to be M3, mounting the sensors is a pain but not difficult, the wiring is easy if you pick it out of a complete loom, you can see exactly where everything goes and what it does by following the WDS. The only thing it won't tell you is how to wire the fault light, but there is info about this on the US forums and again its quite simple.
This will give you the output you may or may not need for the ECU to keep the auto-box happy
Demlotcrew
Mon Apr 18, 2016 11:01 am
chu346 wrote:Seeing as I need the clocks and abs sensor. I wouldn't mind dsc and abs system, so is it still not worth it?
Chu, the Bosch 5.7 wheel speed output to the Instrument Cluster and ECU is not the same as the MK60.
I have a digital wheel speed conversion kit for customers who upgrade E39's. This enables correct signals for correct function.
Andrew
chu346
Mon Apr 18, 2016 1:59 pm
Demlotcrew wrote: I have a digital wheel speed conversion kit for customers who upgrade E39's. This enables correct signals for correct function.
do you have something to give the ECU road speed signal without getting the abs or dsc involved?
