Hi there, I mounted the engine in the car today and found that the e30 mounts were to small and the engine was hitting on the subframe but only by a tiny bit. What other options do I have?
Cheers Phil
What rubber mounts?
I've 300mm.de engine arms with E34 V8 rubbers. That combination doesn't clear the steering rack & support (LHS has to be modified slightly) so you need to put e.g. 3-5mm spacers in there.
There's plenty of room in the "bolts" for spacers so no worries, only problem is the engine coming "too high" (touching the bonnet) at some stage..
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
