Where does this hose go
Tue Aug 02, 2011 1:43 pm
Where does the small hose from the bottom left of the throttle body go???
Its connected to a black plastic tube then back to a hose?
Is it a vacum or summit
It goes down and under the inlet, the top can be seen in the centre of the picture.
Thanks Tom.
chips
Was Pzero
Was Pzero
Tue Aug 02, 2011 2:35 pm
Something to do with the hydro brakes I think. That's the direction it heads off in but I can't remember what I pulled it off when I took the car apart. But I have been wondering myself.
BaldBimmer
Wed Aug 03, 2011 8:48 am
I had the same trouble trying to remember where that went. I ended up just blocking it off with a rubber cap, engine all works fine so I'm assuming you don't need it. Unless your fitting the hydro brakes.
200272
Wed Aug 03, 2011 9:25 am
Cheers thats what i have done.
Jonsku
Mon Aug 22, 2011 5:03 am
V8 E32 / E34 do not have hydro brakes...
The hose is either for the brake booster or for the thingies that try to control fuel tank / intake manifold breathing. Anyways, just get rid of it (as long as you've vacuum for brake booster if you have one) and block the outputs on the intake manifold.
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
chips
Was Pzero
Was Pzero
Mon Aug 22, 2011 8:58 am
My E34 V8 definitely had hydroboost.
Jonsku
Tue Aug 23, 2011 7:48 am
chips wrote:My E34 V8 definitely had hydroboost.
Do the models with steering on the "wrong side" (right) have hydroboost for brakes? I've disassembled four V8 E32 / E34:s and all of them had remote brake servo..
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
chips
Was Pzero
Was Pzero
Tue Aug 23, 2011 9:14 am
They could do, I'm not sure. I remember speaking to someone who had to source a remote servo from Europe for his conversion.
