Heater matrix piping
daniboi328
Tue May 06, 2014 12:30 am
Hey guys a bit off advice urgently needed
Fitted the s50b30 into the car today minus the gearbox (so the engine is leaning forward on the mounts) and I've noticed the two heater matrix pipes are within about 25-35mm from the engine itself, what's the best way to get around this ? 90 degree piping maybe ?
What have you guys done ?
Any pics and advice would be greatly appreciated
Regards
Dan
jmc330i
Tue May 06, 2014 7:22 am
You need two 90 degree bends off the heater stubs, I used some samco bends and two hose joiners. You will also need to cut the stubs so they are a bit shorter.
I cut mine so they were level with the surrounding bulkhead insulation stuff (so I could get at the jubilee clips easier), but it was still very tight. Not sure I've got any pics showing it, but I'll check later.
Some people cut the pipes level with the bulkhead itself and access the jubilee clips from inside/under the dash, but I preferred to have the majority of the join in the engine bay.
James
'91 325i Sport
'93 318i touring 16v
daniboi328
Wed May 07, 2014 5:45 pm
Brilliant stuff bud
Did you have any luck with the pics ?
