wiring s50b32
moggie
does anyone have the correct wiring chart for s50b32 into 325 sport.i have a couple from years ago but there for s50b32 into e30 318,and m50 into e30 318 and last time my auto electrician had a few problems as a lot of the wires didnt match up,we got there in the end but it was very time consuming,worth to mention mine was originally an auto 325 sport converted to manual before the s50 swap.
moggie
i found the wiring tables in the wiki for m50 to e30,are they the same as s50 wiring?
mattxr2
m50 is different from the searches iv done, i have a diagram from an e30 m3 to s50b32 if thats of interest to you.
would like to see your diagram for a 318 if possible, would have thought the pin outs would be very similar
moggie
http://www.rmeuropean.com/bmw-e30-m50-swap.aspx
did my last one off this table but still had some wires that didnt match my auto electrician also had a wiring table he brought but that still didnt match also,
yes im interested in the one you have just to see if it matches the one my electrician has
rich318i
the pins are the same, even if the colours dont match worked on mine and used the same wiring from that site
mattxr2
iv already done an m52 conversion, wanted to see the diagram for s50 b32 into a 318
m3-s50
http://www.cityofdust.com/s50/e30%20s50%20wiring.pdf
m3-s50
